RCU Forums - View Single Post - Mini Titan thread
Old 07-04-2008 | 10:21 PM
  #423
osterizer
Default RE: Mini Titan thread
Your horns should be set up so that when you're at mid stick/zero pitch (and 50% on the pitch curve), the horns are level and the links to the swash are vertical. This should give you even travel up and down. Once that's done, you can set the pitch volume in your CCPM settings to the range you want.
