RE: GST 7.7 brake linkage problem ?
well, does your truck stop fine?? if it does then yes it good!! but it does not look any worse than any others I have seen. If you want the levers to be more perpeicular then you could try to tighten the "cage" screws that secure the pads but you dont want to tighten them so much that you cause draging.
