Prop hole too big
I have a new prop with a hole that is too big for the shaft. The prop vibrates due to being off center when the engine runs. Any good/easy/quick way to make this prop fit? I thought of winding some real thin copper wire around the engine shaft or using several layers of heat shrink tubing over the shaft. Wrap electrical tape? Maybe there is another, better way?
Bob
