RE: engine overheating help
I have the same motor and haven't had any overheating issues. The only thing I might suggest is to use a smaller diameter prop. This engine is made to scream and POSSIBLY the 14" prop is a bit large, even though the text might suggest otherwise. I run a 12x6 prop, maybe try something along that line to check for improvement. What kind of RPM's do you get with the cuurent prop?
