I wanto buy the following ESC and BEC but I don't know is it compatible with each other. Can someone see it and let me know? I'm installing both of it on my Stock Belt-CP. I don't have a ferrite ring. I use 3S1P 11.1 2200mah 20c Lipo, Tower Pro sg90 servo. Which BEC you recommend for the ESC?
ESC
GWS Brushless ESC 35A 2-4S 3A BEC, Speed Controller.
Weight: 22g
BEC: 3A
BEC1
Spec.
Output: 5v/3A or 6v/3A (Selectable via jumper)
Noise: <50mVp-p(@2A/12v)
Input: 5.5v-23v (2-5S Lipo pack, 5-15cells NiMh)
Weight: 7.5g
Features:
Over current and over heat protection.
Switching frequency 300khz.
Chip Efficiency is 92%. This UBEC utilises switching technology to gain a much higher efficiency than liniar BEC. Which means less heat and longer battery life.
The UBEC is equiped with a noise reduction alloy housing to reduce noise even further.
Incorrect polarity safety feature ensures the UBEC will not be destroyed should the battery be connected incorrectly.
https://www.unitedhobbies.com/UNITED...idProduct=4319
or BEC2
Spec.
Output (Constant): 5v/5A or 6v/5A
Input: 8v-42v (3-10cell lipo) High Voltage
Weight: 37g
Quiescent current: 20mA
Features:
Type: Switching, however because of the noise reduction (thin metal case & filter) this unit gives the same noise as a Linear BEC.
https://www.unitedhobbies.com/UNITED...idProduct=6320
