RE: Comp ARF Flash update
Guys,
My Flash was maidened last friday, she flew great, no trim needed at all. One comment from the test flight was that when you did a roll they were "barrely", this was put down to having more down aileron than up. When I got home I check the instructions and Comp Arf recommend having 2mm less up movement on the ailerons than down, this apparently is to compensate for the top hinge on the ailerons. What is the general opinion on this - how does your flash roll? Have you got equal movement up/down? Please let me know?
Thanks in Advance
Nick
