RCU Forums - View Single Post - engine overheating help
Old 07-07-2008 | 01:03 PM
opjose's Avatar
opjose
Default RE: engine overheating help
I fly this engine all the time on different planes. Some with fairly enclosed/restricted cowls...
The prop you are using is your most likely problem.
Use a smaller higher pitch prop.
Get a temperature guage and measure the head temp just off the glow plug.
Run the engine at full throttle for 3 minutes on the ground and immediately measure the temp.
If it's over 340 degrees F, richen the engine settings until the engine stays around 310 or lower.
