RE: Idle Issue
Sometimes the small plastic retainers need to be bent down slightly, so that they keep the metal contacts from sliding out. They may be broken. If so, buy a servo lead to repair the connector.
Your idle setting could be set too lean, causing the idle to run away on you.
