RCU Forums - View Single Post - Composite-ARF Integral, kinda build thread
Old 07-08-2008 | 04:02 AM
  #725
Nickolas's Avatar
Nickolas
Default RE: Composite-ARF Integral, kinda build thread
ORIGINAL: Nickolas
ORIGINAL: JAS
Hi Nikos,
Great in-flight shots. Sounds like you are getting used to it and enjoying it. As for the right aileron, I have the same in mine. Since it's trimmed in the radio, for me it's ok. You can probably change the left wing and move the LE up a little to try and fix it.
Jason
Jason thanks for the answer. If the plane needs right ail trim, then without trim rolls to the left, if I raise the left LE than it will roll even more to the left. Isn't that correct?
Thanks and regards,
Nikos
You are correct... I thought you were refering to the TE...sorry fast reading...
