RCU Forums - View Single Post - Smallest trimmer for conversion?
Old 07-08-2008 | 08:31 AM
deadcell's Avatar
deadcell
Default RE: Smallest trimmer for conversion?
ORIGINAL: buck1856
On that engine your going to find that the starter pawl is left hand thread,only 3/8ths inch long,and not tapered.What i would do is take off flywheel,cut out center with hole saw.Then i would turn the crank around in the case and then put the cut off flywheel center on the crank and screw a prop hub to that.Then run on gas/glow,or use a battery cdi.Weedies use the same bearing and same seal on both ends.The engine wont know wich end is front or back.
How much gas do you mix with how much glow?
How do you put a teenie weenie glow plug in the big hole where the sparkplug goes?
Not to seem stupid but isn't that going against the idea of using an engine because the fuel for it is cheaper?
I mean gas is high at $4 a gallon, but thats still way cheaper than $15 to $20 a gallon for glow fuel.
