RE: satio 100
What type of starter? I use a geared starter and it starts a Satio 300 twin with no problems. Winding the engine backwards to comp and then try. Some starters need a little wind up time. Also how good is the battery you are using?
Also check out [link=http://saito-engines.info/throttle_setup.html]HERE[/link] for proper setup.
Cheers
