RCU Forums - View Single Post - Mini Titan thread
Old 07-09-2008 | 01:11 AM
  #453
Friday_2006
Default RE: Mini Titan thread
I just saw that Mini Titans esc bec works at 5V. Does that mean that each servo now works at 4,8V and not 6V ???????
The above statement i ve made is correct ? Do my servos work at 4,8V or 6V ?
Sometimes i have my receiver (AR6200) blinking (without causing me any problems) and gyro light blinking also, while it would stay on or off.
Does anybody with the same receiver and gyro gets the same blinking lights as i do ?
So Osterizer you are right. Voltage wasn't the source of my problem. Tried to play a little by moving the servo front and back and seemed to cure it a bit, but didn't eliminate it. Tail travel is ok, It goes from far left to far right without binding.
Today i ll try to setup tail and head from the beggining and see if that problem stops.
16A max for the one vs 29A for the JGF. 29A will be about 300W
Can you tell us how you did this calculation ?????
Thanks !
