RCU Forums - View Single Post - Smallest trimmer for conversion?
Old 07-09-2008 | 11:34 AM
deadcell's Avatar
deadcell
Default RE: Smallest trimmer for conversion?
ORIGINAL: buck1856
Your not using that much oil,your to buy the 10 percent nitro,10 percent oil content glow fuel.When mixed with the gas you probably only have about 8% oil content maybe.And the ryobi will never have the power of a Q50.Look up ryobi 31 in the search bar under this forum and youll see what it flies.The ryobi may fly it but i dont think very good,but i could be wrong depending on weight.
I think it was around 14 lbs.
When I first got it, it had a 32 mcculloch that had been converted.
Then I switched to a Quadra 38, then finally ended up with the Q50.
The 32 would fly it, but nothing like the Q50 would.
I'm not expecting alot from the Ryobi.
Maybe I should be looking in another direction for this.
