TT 21 problems
A friend of mine has a TT 21 outboard engine and today hit the prop off the warf he was running the boat from. The prop now does not engage and when the engine is running. I took the engine apart and everything is fine except the prop shaft doesn't engage the main flex shaft. It looks to me like something like a shear pin or something is broke and would like a part # or some advice on a solution to the problem. Thanks
James
