RE: hitec servo ????
when running 2 individual servos such as elevator control, you must make sure both elevator arms / links are set at the same distance so both will have equal throws. if one arm is slightly out from the other side arm you won,t have the same throws. have a close look at the elevator arms and compare how even they are to the stab, if one is 1mm off you have the problem.
