Congats Phattracker on the birth of your daughter
Windowlicker.....If your shell is an rtr you will probably find the paint is printed on before they form the shell...if this is the case then Nail varnish remover will get it off with some effort but without clouding the shell as brake fluid does....but you will need to find nail varnish remover that is Acetone free, the one I tried that contained it didn't work at all...the one I used that works contains ethyl acetate...it's hard work but the results are promising, just got to get some more as I've used up the last of wifeys
