RCU Forums - View Single Post - Venus 40 CG
Thread: Venus 40 CG
Old 07-12-2008 | 11:54 PM
rainedave's Avatar
rainedave
Default Venus 40 CG
Hi all. To those of you flying the Venus 40, where are you setting the CG? I have been flying mine at the manual's recommended location and it flies very nose heavy (hard to break ground and lands hot). I used this calculator - http://www.geistware.com/rcmodeling/cg_super_calc.htm - and determined that the manual's location is at about 24.5%. So, that explains the nose heavy qualities. I will try moving it back 1/8" or so at a time, but if anyone has already worked out an optimum location it would save me a bit of fiddling around with radio gear. Overall, I'm happy with the plane. I'm using an AX .55; it weighs 5.5lbs.
David
