RE: starting problem
Are you priming the engine? Is fuel getting to the engine?
Try givving it a bit of throttal when you start it and to check the glow plug get a pair of needle nose pliers and then hold the par that inserts into the engine and then attach the glow starter to it if it glows then its fine..
Andrew
