starting problem
FL
i haev a os 18 tm installed in a kightning gt10 and it won't start.it sounds like it wants to but it can't.what could be the problem?i was at my hobby store and they ran it and tuned it and it ran and started fine and when i got it home it started then stalled and wouldn't start again.
AZ
Can you see fuel getting to the carb? Have you pulled out your glow plug to see if it glows with your ignitor? Doesn't take much to get one to start, I can even get an engine with a horrible tune to start.
Are you priming the engine? Is fuel getting to the engine?
Try givving it a bit of throttal when you start it and to check the glow plug get a pair of needle nose pliers and then hold the par that inserts into the engine and then attach the glow starter to it if it glows then its fine..
Andrew
Andrew
There are a few area's to consider when the engine won't start.
My thought right off the bat is, how old is the fuel that you using at home? What nitro % is the fuel it was broke in at, and what % you have at home, and what % did they use at the shop?
Pull start or start box?
If the fuel is not getting to the engine, put your finger over the exhaust and starting it, that will force the fuel to the engine. after the fuel gets there, take your finger off.
I would say dump the fuel. Buy some new fuel with the right nitro % and prime the engine, and it should start.
FL
i gave it throttle,checked the glow lug,rimed the engine,it has been 20% the whole time.electric starter.fuel is getting to the engine.
