RCU Forums - View Single Post - :: Official MBX5/Prospec Thread !!
Old 07-13-2008 | 06:22 PM
  #1316
dicko's Avatar
dicko
Default RE: :: Official MBX5/Prospec Thread !!
you can dummy build the CV joint, when you do up the grub screw it will mark the pin, then you know where to cut. I also blunt the tip of the grub screw so it has a larger contact surface on the pin and use GOOD thread lock, not cheap duratrax stuff. buy the real deal.
