Travel Limiter Needed?
I have a Trex 450SA with a HH gyro that does not allow me to limit the travel enough. I have decided to build a small device that will limit the travel. This device will be very small and connect between the servo and the gyro (or a rx). It will have a small pot to set how much you want the travel limited. Would anyone be interested in this device if I made more then one?
The problem with this is many radios don't have a setting to adjust travel and many people open them up and solder a resistor. The problem with that is it will always be limited. Even with that modification it still would not work with a HH gyro.
Thanks for the responses,
Justin
