Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
View Poll Results: A poll
Yes
66.67%
No
33.33%
Possiably
0
0%
Voters: 3. You may not vote on this poll
Travel Limiter Needed?
Old 07-13-2008 | 06:57 PM
Commander_Bob's Avatar
Default Travel Limiter Needed?
I have a Trex 450SA with a HH gyro that does not allow me to limit the travel enough. I have decided to build a small device that will limit the travel. This device will be very small and connect between the servo and the gyro (or a rx). It will have a small pot to set how much you want the travel limited. Would anyone be interested in this device if I made more then one?
The problem with this is many radios don't have a setting to adjust travel and many people open them up and solder a resistor. The problem with that is it will always be limited. Even with that modification it still would not work with a HH gyro.
Thanks for the responses,
Justin
Old 07-13-2008 | 10:56 PM
Default RE: Travel Limiter Needed?
Use a digital servo, travel limit and center are settable.
Old 07-14-2008 | 12:52 AM
I have a digital servo. How do you set it? It is a S9650.
Justin
Old 07-14-2008 | 03:15 PM
-pkh-'s Avatar
Move the control rod in on the servo arm (closer to the servo's shaft) and/or move the control rod out on the control arm for the tail rotor pitch.
Old 07-14-2008 | 03:53 PM
That is how I currently have it. The problem is the servo has to move a lot more. The control rod is as close to the servos shaft as possible and it still almost binds.
Justin
