RE: Maiden tips
I have found it useful to carefully check all control surface alignments using a Robart Incidence meter. I set the stab at true level using a small level on both sides, then set the elevators with the radio on using the Incidence meter. Then I go to each wing/aileron and do the same making sure the stab stays level.
