ok...will do! thanx for the tip on blunting the end of the grub screw! (did you use the same dremel wheel as the one to make the notch in the pin?)
oh, i use the tamiya blue lock-tite per advice from the forums! it seems to hold well...however, the tube is oozing from the neck so there's constantly a dried blue blob on the side!
