RCU Forums - View Single Post - Predator Outrigger Project
Old 07-16-2008 | 07:55 AM
ryan_t888's Avatar
ryan_t888
Default RE: Predator Outrigger Project
If you have rear sponsons / rear ride pads on the hull, your prop shaft must be run parallel with the water using a low lift prop.
Fiend is using a wire drive.
I prefer flex shafts only. For this project a .130" flex with 3/16" shaft stepped down to 1/8" will work great for brushed and brushless applications.
Ryan
