ORIGINAL: BudBud
I actually had opened the HSN needle an was a little rich, I also had backed out the second hear clutch so it engaged almost immediately. I was trying to show the stability of the chassis and not the power of the engine, just prior to this I had been ripping long wheelies in the street, when I tried to run it in the rink, it kept flipping clear over backwards, unstantly over backwards. I must have lost the clutch bearing at about the same time I started filming. BB
okay that makes sense !!! I was hearing the motor drop down in RPM so I was thinking she was lean and running out of fuel..I didnt realise you were letting off the trigger........ Common man lets see some top end runs with full RPM on concrete !!!...... I usually find a slightly richer HSN produces better RPM then a slightly leaner top end.....
