RE: HOW TO BREAK AN ENGINE IN!!!!!!
Sadly, that re-pinching process will not add any life to your engine.
It will however, result in an out of round sleeve with a tight spot or two, fooling you into believing that you have added 'pinch' back to the engine.
The piston and sleeve will wear quickly, leaving you with a dead mill.
BTDT.
I've tried every method of re-pinching an engine you can possibly think of and only one works.
[link=http://rayaracing.com/]Raya Racing[/link]
This is the same procedure that the factories use to 'pinch' a sleeve when they are made.
Scott
