Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Truggy
 HOW TO BREAK AN ENGINE IN!!!!!! >
RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
Old 07-10-2008 | 10:13 PM
DS's Avatar
DS
Default RE: HOW TO BREAK AN ENGINE IN!!!!!!
how do you know if the piston is dead in the center is it like that before u break it in
Old 07-13-2008 | 05:42 AM
j_blaze's Avatar
i still say the drake method is the best. half hour, no chance for fly aways or overdriving, no snapped con rods, no overheating or under heating. the only thing to worry about is the noise, wear ear plugs.
Old 07-13-2008 | 09:17 AM
Force4x4's Avatar
ORIGINAL: st1_racer
anyone help me
Take the glow plug out and watch the piston!
Old 07-13-2008 | 10:12 AM
ORIGINAL: st1_racer
anyone help me
what i do is i move the piston till it starts to get tight and then i go back the other way till the piston gets tight then i go by what i feel is the bottom
Old 07-13-2008 | 10:47 AM
DS's Avatar
DS
Default RE: [Awaiting Approval]
ok so turn the flywheel before i break it in to see if its at the bottom?
Old 07-13-2008 | 11:11 AM
  #31
not before after you run it when it cools you want to have it at bdc so the sleve will still have pinch
Old 07-13-2008 | 02:27 PM
  #32
windowlicker's Avatar
make a mark on the bottom of the flywheel with a marker pen so you know where bdc is. Then its much quicker to put it at BDC when you are finished running
Old 07-13-2008 | 02:46 PM
  #33
the last time i did that the mark went away
Old 07-13-2008 | 03:04 PM
  #34
try scratching it, I've done that with my Firestorm. use a screw driver and scratch a line
Old 07-13-2008 | 03:12 PM
  #35
i never thought about that lol
Old 07-13-2008 | 08:51 PM
  #36
ORIGINAL: madmax22
yes you do but you dont have to go as easy on it as when it was new.
will the repinching process work with a glass top stove?
Old 07-16-2008 | 02:26 PM
  #37
Sadly, that re-pinching process will not add any life to your engine.
It will however, result in an out of round sleeve with a tight spot or two, fooling you into believing that you have added 'pinch' back to the engine.
The piston and sleeve will wear quickly, leaving you with a dead mill.
BTDT.
I've tried every method of re-pinching an engine you can possibly think of and only one works.
[link=http://rayaracing.com/]Raya Racing[/link]
This is the same procedure that the factories use to 'pinch' a sleeve when they are made.
Scott
Old 07-20-2008 | 10:40 PM
  #38
madmax22's Avatar
rebel if you want to still do it i think it would work just put it on HI and let it warm up for a little bit!
Old 07-21-2008 | 12:44 AM
  #39
phattracker's Avatar
ORIGINAL: st1_racer
HOW DO YOU GET YOU PISTON DROP DEAD IN THE CENTER, AND HOW DO YOU KNOW. CAN SOMEONE HELP?
Without taking the head and button off to actually look. Roll the engine over by hand, feel the pinch yet? Now do it again. Now mentally draw a pic in your head of whats going on in the engine, up down up down. Just split the difference in between the pinch and the point of least resistance. The piston will go full stroke per turn of the flywheel so when you feel the least resistance, that is most likely gonna be close to BDC. Or just take the cooling head and button off and actually look. Mark the flywheel with a sharp knife or a screw driver or sumthin, on the top of the flywheel. This way when your done playin, roll the motor over till the mark you made is where you know BDC is. Easy ain't it? I use a sharpie to mark mine because I take my motors apart and inspect them often, and the sharpie will eventually cook away leaving me with no mark on the flywheel anymore. And when the sharpie mark is gone, then I know its time to take the mill apart and check things out. Put it back together, check BDC, make my mark, and let it rip. Hope this helps you out.
