RE: Walbro replacement gasket set
If you are running straight gasoline you can use either membrane. The one that is like plastic film (brown) I believe can be used with nitro as well. I have one like that but it's blue and works with a gas/glow mix. I had problems with a black plastic membrane in a Zama carb when I used it with gas/glow however.
