Hey Wreckman and Smallfly-
Do I have these longerons in correctly in the tail area? The only ones that I'm not sure about are the ones on the top. I believe that is F9, which according to the manual, the longerons should overlap by 5mm. It seems to obstruct the stab mounting bracket though. Is that just supposed to be trimmed away, or do I have it in the wrong place? I haven't glued anything yet because I wanted to ask you guys about it.
Thanks!
Reid
My "out" markings on the fuse are wrong. They're old. I'm definitely NOT building two sides of a fuselage! Although I have done that in the past...
