RCU Forums - View Single Post - How do I get CA out of the control surface hinges?
Old 07-18-2008 | 08:47 AM
MinnFlyer's Avatar
MinnFlyer
Default RE: How do I get CA out of the control surface hinges?
Not a problem, put a few drops of acetone right on the pin and work it in. Follow it with enough acetone to flush out some of the loosened CA. Then add a few drops of penetrating oil.
The Acetone won't be able to travel very far at all into the slot holding the hinge, and even if it does, once it evaporates, the CA will re-harden.
