RCU Forums - View Single Post - SF .46P setup
Old 07-18-2008 | 09:54 AM
Bax
Default RE: SF .46P setup
Your hookup is correct. With a pump, you don't need a pressure fitting on the pipe. The tank vent should go from top-forward inside the tank and exit out the bottom of the fuselage.
