O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
SF .46P setup
Old 07-18-2008 | 09:42 AM
rainedave's Avatar
Default SF .46P setup
Dear Bax:
I have downloaded both the OS PA-104 Pump System instructions and the Hobbico OS Pumper Engine's Carburetor instructions and read them.
My question is:
Should I plug the pressure fitting on my tuned pipe and leave the pressure tube on my tank open as a vent?
I have attached a photo showing my setup. Am I correct in plugging the pipe's pressure fitting? Or, do I want to connect it to the tank?
Thank in advance.
David
Old 07-18-2008 | 09:54 AM
Bax
Default RE: SF .46P setup
Your hookup is correct. With a pump, you don't need a pressure fitting on the pipe. The tank vent should go from top-forward inside the tank and exit out the bottom of the fuselage.
Old 07-18-2008 | 10:14 AM
rainedave's Avatar
Thank for the fast reply!
David
