RCU Forums - View Single Post - broken G4 simulator Control
Old 07-19-2008 | 01:31 PM
Bugzilla's Avatar
Bugzilla
Default RE: broken G4 simulator Control
First you say,
ORIGINAL: falcon3dfever
Just broke my g3.5 control..is there a way to use any futaba radio to run g4? Any modification available? Thanks
Then you say,
Thank you guys for your help. I forgot to say that I do not have interlink. I just have the control connected to the pc usb port (I had G3 and upgradedto 3.5) . Is there a way to prepare a cable and connect the Futaba into the usb? Thanks
I hope you didn't throw it away or anything, because you cannot control G3.5 or G4 without the original controller, also called the Interlink. The program will not allow it. You can use any radio as a controller but you have to have it plugged into the original controller, and the original plugged into the USB port.
