RCU Forums - View Single Post - the hyper st PRO thread!
Old 07-20-2008 | 05:09 PM
  #1300
j_blaze's Avatar
j_blaze
Default RE: the hyper st PRO thread!
ORIGINAL: PatrickBW
Have you guys not had problems with the carriers? Like everybody here has had issues with threads stripping, or just outright breaking.. They appear to be the worst level of junk.. And given what they cost..., jeeze.. Mine stripped out basically within two days. It's happened pretty much to everybody in the German forum I go to.. Have a screw going in opposite direction, held with a nut at the mo.. Luckily a guy at the track who'd had the same problem helped get it fixed..
Talking to another guy now who's made some X-ray ones fit somehow, but I think I'll just order the cheap alu RTR ones for backups..
which "carrieres"? do you mean the knuckles in the front or rear hub carrier? i had to use slightly longer screws in the front ones because the stock ones did not use all the threads, i did have a set back out early on. blue locktite and they have been fine since. i'm also using the CEN aluminum c-hubs for now, seem to work perfectly.
