RCU Forums - View Single Post - 24 lb plane and 3w75?
Old 07-20-2008 | 09:08 PM
bjamesjr
Default RE: 24 lb plane and 3w75?
ORIGINAL: chipper11077
Hey guys and girls,
I'm wondering what you all think or if anybody has first hand experience.
I have a highly modified 33% Lanier Extra that I am working on setting up. Unfortunately right now funds are very tight so I am looking to do things as cheaply as possible. It looks like if I use the 3w75IUS that I have the plane will come in at almost exactly 24 pounds.
Has anybody flown a plane around this weight with this engine? I'm not looking for a 3D monster but I want plenty of power for good IMAC type flying and maybe a hover if possible.
I was originally looking at buying a friends 3w80xi which would probably have been perfect but who knows when I will have the money to do that. I don't want to wait forever but I don't want to finish the plane with the 75 and it be a dog either.
I have read several different posts on here about this and a few guys have said yay and a few ney...
For what it's worth I am pretty much at sea level.
Let me know what you think!!!
Thanks in advance!!!
Scott
Hey Scott,
We've met before. I had the username of bubbagates for a long time.
Anyway,
I had a C-Arf 2.3 at 21lbs on a 3W70US turning a PT models 24x10 and it would take that plane vertical like gravity was a passing fancy and if I bolted on a 24x10 MSC prop it even pulled harder but was a bit jumpy for the plane. I could come along level at 1/2 stick and plant it and you could easily see the plane leap forward.
I'm totalling guessing but I think the 75 will pull a 24lb plane around fairly well but for IMAC, much past sportsman would be difficult at best. You'd probably hover at close if not full throttle so you had beeter be on your game and if it's hot out hovering or any reasonble vertical may be out of the question.
Again, I'm guessing based on expereince with a 5cc less engine on a 3lb lighter plane
