RCU Forums - View Single Post - Turbine Engine Oil
Old 07-20-2008 | 09:10 PM
tinsink
Default RE: Turbine Engine Oil
this is good news. I hope you run these engines for several flights then disassemble for inspection. Please let us know
if the ongoing flights have the same power as the first. Did you use the 15% turbine oil? As I recall, and this was almost 20 years
ago when I worked for Avco Lycoming turbine division, the oil was made to mil spec 7808 so you can check the flash point and compare it to
castor or synthetic glow oil. Interestingly enough 7808 did not specify synthetic or organic oil so that some was synthetic and some organic, that is, it was made with animal fat. You could always tell when you were using certain brands because in the summer heat they smelled awful.
