RE: dual elevator pushrod setup
well, i ordered the DEPS pushrod system from central hobbies and i was disappointed in the friction between the clear tubes and the CF rods. quite a bit of drag between them. i also found out you can't have your receiver antennae wire inside the fuse with CF pushrods. hence the search for other methods. thx, david
