RE: DL-50 engine
The menz has too light a load If they make a 23 X 8 that is what you need to run or get a Vess 22B. You need to tune the engine in for optimum performance and that prop just isn't going to get it. I would think the max RPM i would want to see on the ground would be in the range of 7000 to 7300 because it will unload in the air.
