RE: GO .25 Breakin in (heat cycle) F-UP!
I have put three tanks thru my Go .21 5 port with this break in method. It has worked great with good temps. I pulled the motor apart because I noticed some metal shavings on plug but motor looks fine. Will replace the bearings to be safe. There was plenty of oil in the engine so I know its getting lubed properly. This is taken off of the rctech.net go tech forum. Give it a shot as it works pretty good.
There are various break in methods out there, but the one I have cut and pasted below is from Brian at Pro Twister Mods (mugen46). They are Go-Tech distributors and specialise in modding the Go engines, so they know what they are talking about. The original thread is at the bottom of page 78 on this forum. Follow this procedure and you should be sweet. I have broken in my Go engines using this method and they all run great.
¨GO engine breakin
there are alot of ways to breakin a engine and alot of different opinions on which way is right. I use what i think is somewhat aggressive style, but it still gets adequate fuel through the motor without killing the rod and piston.
Needle setting out of the box. where ever it is set, i always putthe HSN flush or even a hour abouve fluch, and the LSN 1 1/2 turns in from flush, this makes idle during breakin consistant and idles well with good temp, when temps drop the motor will let you know, it makes a very distinctive pinging or tinking noise, the sleeve is shrinking and killing the piston and rod, low heat during breakin is the #1 contributer to broke wrist pin tabs on GO pistons, and the high rpms later on. good heat during breakin will keep good compresion in the motor in the later galloms of the motors life with out being to tight. and will hold a good idle at race temps.
Installing the engine.
After run oil is great. I soak the inside with it befor putting it on the car, let the extra run out the exaust port onto a rag, but be prepared for some smoke on start up. once you have the engine in the car and the exaUST on you are ready for some blowing, yes blowing. Blow in to the stinger of the pipe, you will see fuel going through the lines and into the carb, you can hear it enter the carb making a bubbly noise, when the fuel goes into the carb do it for about 2 seconds after that, then lift the car and turn the flywheel back and forth, this will basicly prime the engine without any dry rotation and coat the inside and also give a faster charge of fuel to help it start up, but heat it first, use foil on the head and preheat the engine with the plug just a tic loose, heat it to about 240 and crank it, remember you have fuel in the carb already so if needed you can apply some throttle to help it get going, just not alot, it doesn't take much with the LSN being set where it is, once it fires tighten the plug and go right to watching the temp, on the first tank keep it at 24o or so the entire tank, then return to BDC and let it cool to about 115.
Now is when i put the car on the ground, i adjust my idle screw to help when applying break not to close the carb. Now that the first tank has been done i start from one and go from here with foil still on the head and my needle settings.
Tanks 1 -6 idle to 1/2 throttle
lean LSN 1 hour and turn down idle screw
Tanks 7 - 12 idle to full throttle easy RPM climb
Go to the track and race tune from there, the HSN may only get turned 2 hours, but the low end will go farther, this setting will give great snap on the bottom and a good transistion to mid and top with good smoke the whole way. when you get to the track pull off the foil and go, if the temp go to 240 260 during 7 - 12 it's fine the settings are still fat you will see how much by the smoke, with this breakin the power robbing pinch will go in about a gallon. after that mark the temps will fall and the final race tune settings can be applied, trying to lean the engine with alot of metal pinch can cause iot to lean bog, flush the HS and lean the LS and the temps will be normal 3 or 4 hours leaning on a tight motor will not work during breakin, with these setting out of the box and changed to what i use the engine will be slightly blubbery on top but be able to get the car moving pretty easy off the bottom.¨
