RE: GO .25 Breakin in (heat cycle) F-UP!
that go 25 will not run well on tornado 16%,get some 25% or even 30% as this is what go motors are shimmed to run.it will run hot until the pinch has gone from the piston/sleeve as the excessive friction near tdc will cause extra heat.
