duratrax raze st
recently purchased the duratrax raze st rtr with the super tiger G-27CS from towerhobbies.com all info here
This is the 1/8 scale glow powered, radio controlled, ready to run
Duratrax Raze Off-Road ST Truggy.
FEATURES: Chassis: 0.12" (3mm) thick aluminum, anodized blue in color with
molded plastic chassis side guards and built-in transponder mount
(transponder not included)
Drive: Four wheel shaft drive
Radio: Duratrax by Futaba FM pistol grip/two servos, micro receiver
with 3rd channel for transponder use, servo reverse, steering
and throttle trims and dual rate, transmitter does not have charge
jack
Radio Box: Sealed
Electric Starter: DuraTrax Kwik-Pit Super Start with 540 size motor
(DTXP6023)
Engine: Supertigre G-27CS .27 cu in (4.4cc) ABC cylinder and liner
construction, Super Start (DTXP6018), glow plug, dual ball bearing
supported crankshaft, slide valve carburetor, 2.5 hp at 30,000 RPM
Exhaust: Aluminum tuned pipe
Engine Mount: Aluminum, adjustable
Fuel Tank: 5.1oz (150cc), flip top cap
Clutch: 3-shoe racing type
Ball Bearings: Full set, 20 total
Shocks: Oil-filled with aluminum bodies, coil-over springs and
multiple shock mounting and camber positions, 0.16" (4mm) thick
shock towers
Main Gear: 62 tooth, hardened steel
Differentials: Three, sealed adjustable with metal internal spider
gears, front and rear diff cases remove easily for maintenance
Brakes: Dual disc with adjustable bias
Tires: 6.1" (155mm) diameter, 3.34" (85mm) wide with foam inserts and
off-road tread
Wheels: White plastic 6.1" (155mm) diameter, 3.34" (85mm) wide, 17mm
hex
Body: Painted with decals applied
Bumpers: Front, hardened plastic
Suspension: Four wheel independent
Caster: Adjustable, caster/toe-in refers to the angle of the front
suspension when viewed from the side of the car in relation to the
chassis, 2° and 3° rear toe-in blocks included
Camber: Adjustable, camber refers to the angle of the tops of the
tires from vertical when viewed from front or behind vehicle
chassis
Steering: Dual bell crank with servo saver and metal front steering
knuckles, 17mm drive hex is compatible with other 1/8 scale models
Glow Starter: C size
Fuel Bottle: 8.4oz (250cc)
Warranty Period: 90 days on vehicle, 12 months on Stress-Tech plastic
parts (Stress-Tech parts noted in bold type on parts list)
INCLUDES: Duratrax 1/8 Raze ST Truggy with Supertigre G27CS engine w/Super
Start (DTXP6023), glow plug, tires, foam inserts, wheels, FM pistol
grip radio system, two servos, glow starter, fuel bottle,
13 tooth clutch bell, 62 tooth steel spur gear, aluminum bodied
shocks, photo-illustrated instruction manual, instructional DVD
REQUIRES: Radio Batteries: (8) AA size
C-Cell Battery: For glow starter
Engine Starter Battery: 7.2V 6-cell stick battery pack
Battery Charger: Timed or peak for starter battery
Fuel: 2-cycle glow fuel with 20% nitromethane, 16% lubricant-
Most of the fuels we carry meet or exceed the lubricant content
required for optimum performance and maximum engine life. In the
past, the conventional lubricant content used in fuel was 18%. But
with new advanced technologies, fuels like Red Alert and O'Donnell
for example, have a better quality of lubricants even though the
percentages of lubricant content are lower. These high-tech
lubricants provide exceptional cooling and protection.
SPECS: Vehicle-
Length: 20.1" (530mm)
Width: 16.5" (420mm)
Height: 8" (205mm)
Weight: 9lbs (4.1kg)
Wheelbase: 12.5" (317mm)
Tread: 13.25" (336mm) wheels on center side to side
Track: 16" (406mm) wheels at outer edges
Ground Clearance: 1.9" (49mm)
Body-
Length: 18.89" (480mm)
Width: 7.28" (185mm)
Height: 4.52" (115mm)
COMMENTS: The Raze ST Truggy is available in the following body colors and
radio channels;
Green CH 62 DTXD7762
Blue CH 64 DTXD7764
Red CH 68 DTXD7768
Orange CH 70 DTXD7770
Desert CH 72 DTXD7772
Purple CH 74 DTXD7774
For Replacement Ball Bearings use:
Qty. Size Location Qty. Bearing Set
4 8x16mm Front Wheels 2 DTXC1585
4 8x16mm Rear Wheels 2 DTXC1585
4 8x16mm Front Diff 2 DTXC1585
4 8x16mm Center Diff 2 DTXC1585
4 8x16mm Rear Diff 2 DTXC1585
2 5x10mm Clutch 1 DTXC1535
i sent the motor in for possible air leaks they said it was fine put it back in got the mesh right and it wont stay started they didnt touch anything on the motor but i reset everything to almost factory about 1/8 turn off of factory where i had it before replaced clutch bell bearings changed fuel tube and used brand new fuel still wont stay running car has given me nothing but problems since i got it any help will be appreciated
thanks
