RE: Climbing When Inverted
To determine if its a cg or thrust line problem get it straight and level and medium throttle and floor it if it climbs or noses over you need to correct the thrust line. Same with a vertical climb at full power to determine left or right thrust needed.
Once you do that, then you climb at 45 degrees and flip inverted, that will tell you if your cd is correct.
