Oddball Prophub
Guys:
I need an odd prop hub made for a Fuji 23.5 Gas/Glow. The crank is tapped for a 6mmX1.00 pitch, So I plan to add a stud to the crank. So I need a hub about 1 3/4" long tapped on the engine side for 6X1.00mm and I'd prefer the prop side to have 5/16X24 so prop swapping is easier. The 6mm is alittle to small for most of my props..
Anyway ,,,,Any takers???? If so let me know how much and a check will be winging your way.
Rick
