Oddball Prophub
Old 07-23-2008 | 03:55 PM
Default Oddball Prophub
Guys:
I need an odd prop hub made for a Fuji 23.5 Gas/Glow. The crank is tapped for a 6mmX1.00 pitch, So I plan to add a stud to the crank. So I need a hub about 1 3/4" long tapped on the engine side for 6X1.00mm and I'd prefer the prop side to have 5/16X24 so prop swapping is easier. The 6mm is alittle to small for most of my props..
Anyway ,,,,Any takers???? If so let me know how much and a check will be winging your way.
Rick
Old 07-23-2008 | 04:03 PM
seanreit's Avatar
My Feedback: (60)
Default RE: Oddball Prophub
Draw it out on a piece of paper, or something and fax it to 512-287-5338 or email to [email protected] I have a CNC lathe and CNC mill.
Also, put how much you are willing to pay for it. I'm not the cheapest, but I can have it done in a couple of days.
Old 07-24-2008 | 08:02 AM
Dr Honda's Avatar
Hi,
Unless it's going down on a bigger, tapered part of the crank... 6mm threads are too small to support a prop. If it's just a little out of balance... it will snap the crank. On my 19cc Mitsu engines... they have 6mm crank threads, and I made an adaptor to bolt across the old clutch mounts.
Just thought I would throw that out to you.
