Trondhindenes ~
Here
http://www.heli-wiki.com/mediawiki/i..._CP_and_CP_Pro
I also use a heavier batt to lower the CG. A few also use the super skids which are heavier to also help lower it. My servo rods are also moved in a hole on the servo arm, to help reduce the throw. (More tame)
Also I have used the JCS plastic blades. They work good, just make sure ya run the appropriate pinion so you don't overwork your motor. Just one blade weighs as much two woodies, or two CF blades. Check here for the specs on the pinion
http://www.heli-wiki.com/mediawiki/i..._Plasti-Blades
Anyway, good luck !
Jeff
