RE: Oddball Prophub
Hi,
Unless it's going down on a bigger, tapered part of the crank... 6mm threads are too small to support a prop. If it's just a little out of balance... it will snap the crank. On my 19cc Mitsu engines... they have 6mm crank threads, and I made an adaptor to bolt across the old clutch mounts.
Just thought I would throw that out to you.
