RCU Forums - View Single Post - Tower Trainer 40 covering
Old 07-24-2008 | 02:31 PM
opjose's Avatar
opjose
Default RE: Tower Trainer 40 covering
Like he said.
A heat gun is my preferred way of doing this, as it is much quicker and results in a better final result, since you end up heating a larger area at once.
I use a covering mitt as well, to help make sure that the covering adheres properly as it cools.
But seams are a big problem with heat guns.... so I try to first go over the seams with an iron, then work on the big areas with the heat gun.
