 Tower Trainer 40 covering >
Old 07-24-2008 | 12:50 PM
goirish's Avatar
Default Tower Trainer 40 covering
I received a Tower Trainer 40 ARF for my grandson. The covering is wrinkled in many places. Do you know if it can be taken out with the heat gun or the sealing iron. I don't believe that it is monokote or ultracote. Don't want to make it worse than what it is. Thanks
Old 07-24-2008 | 02:17 PM
MinnFlyer's Avatar
Default RE: Tower Trainer 40 covering
Just go over it with an iron Gene. If you need to use a heat gun, don't get too close to any seams. If you MUST get close, lay a wet rag on them to keep them cool.
Old 07-24-2008 | 02:31 PM
opjose's Avatar
Like he said.
A heat gun is my preferred way of doing this, as it is much quicker and results in a better final result, since you end up heating a larger area at once.
I use a covering mitt as well, to help make sure that the covering adheres properly as it cools.
But seams are a big problem with heat guns.... so I try to first go over the seams with an iron, then work on the big areas with the heat gun.
Old 07-24-2008 | 02:36 PM
goirish's Avatar
What ever kind of covering they use it is sticky on the bottom or underneath side of the covering. Almost like shelf paper. Was afraid that it would not shrink. Thanks for the info.
Old 07-24-2008 | 03:06 PM
About every ARF will come in this condition. Climate change from where it was covered, where it was stored and where it's destination is all effect the covering.
As others suggested, take an iron or a heat gun to it. I Use iron on the seams and the gun on areas without the seam, seams to work well
Old 07-24-2008 | 05:21 PM
chemie's Avatar
The covering is "Tower Cote" meaning the TH version of Monocote/Econocote.
Old 07-24-2008 | 06:32 PM
bingo field's Avatar
Pretty soon you will be the go to guy for everything......
Old 07-24-2008 | 08:01 PM
I had the same problem with the covering on my TT. After the 10th flight of so, I had to reseal it after every single day at the field. A tipbut some clear fingernail polish over all the seams on the side your exhaust is on after you seal it all back down. That will prevent the cockpit shape and the trim stripes that run all the way down from coming off.
Old 07-24-2008 | 08:22 PM
goirish's Avatar
ORIGINAL: bingo field
guess I am slow-not sure what you mean when you say the go to guy for everything. Thanks, I think.
Gene
Old 07-25-2008 | 08:05 AM
goirish's Avatar
Geeze!! the heat gun and iron worked great. I have a TH trainer 60 and the covering on that is different than on the 40. When you take it off it is sticky on the back side and seems much heavier than towercote. It does not shrink well.
Old 07-25-2008 | 08:29 AM
MinnFlyer's Avatar
He should have typed it:
the "Go-To" guy
Meaning, you'll be so knowledgeable soon that everyone will "go to" you for all the answers.
