RCU Forums - View Single Post - Genesis motor alignment issue!
Old 07-24-2008 | 08:33 PM
93firebird
Default Genesis motor alignment issue!
I bought my Genesis on Ebay, and who ever set it up has the motor alignment wrong, the second gear pinion is hitting the second gear clutch housing and has worn teeth marks into the edge of the clutch, and the first gear spur is rubbing on the motor clutch, can the motor be moved back or is this a shim issue on the clutch assembly?
